Author Topic: Altium script for schematic  (Read 1946 times)
Offline kmarcineTopic starter
« on: November 21, 2017, 10:37:12 am »
I wonder if there is possibility to write a script that will go through all the components on the schematic/s and for example copy string from one of the parameters (if exists) to a comment field. We have a number of projects done by different engineers in different ways (not always appriopriate) and would like to introduce some common rules and apply them to already existing projects.
Offline tszaboo
Re: Altium script for schematic
« Reply #1 on: November 21, 2017, 10:56:31 am »
Yes.
http://techdocs.altium.com/display/SCRT/Scripting
Probably easier by hand. Unless you like spending 5x as much time to do an x amount of work.
« Reply #2 on: November 21, 2017, 11:22:57 am »
Do anybody has more practical example of script that will allow to manipulate components parameters, comments etc. on the schematic?
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: November 21, 2017, 02:28:31 pm »
Have you used the Parameter Manager before?
Seven Transistor Labs, LLC
The following users thanked this post: kmarcine
« Reply #4 on: November 21, 2017, 03:29:21 pm »
Great, thank you. I don't know how, but I haven't thought about using this tool...
