Author Topic: How do I create a board outline layer so I can generate a layer in Gerbers?  (Read 7868 times)
Offline slow_riderTopic starter
I have finished my design and it seems I am missing a mechanical layer that defines the board outline? Thanks!
Offline ajb
In the PCB editor, hit 'L' to bring up the layers menu, then select "Enable" and "Show" next to the mechanical layer of your choice.  Typically Mechanical Layer 1 is used for the board outline.  Draw the board outline on that layer, then select the outline objects and hit D,S,D to use them to define the board outline.
In your gerber outjob, make sure that your outline layer is selected for plotting.
The following users thanked this post: Scutarius
Online T3sl4co1l
    • Seven Transistor Labs
Hmm, typically Keep-Out Layer is used for outlines, at least that's always been my convention (and Altium's).
In any case, as long as the outline layer ends up in a .GKO Gerber, it'll fit the convention as the board outline file at most fab houses.
Seven Transistor Labs, LLC
