Author Topic: Altium Designer 21 Import P-Cad Files  (Read 1270 times)
Offline derekTopic starter
« on: March 09, 2023, 01:41:45 pm »
I am trying to import P-CAD v8.50 Schematic and PCB files into Altium Designer 21.
The import wizard does not recognise the Schematic and PCB files.
I looked at the files in a text editor, which gave the version of the data files:
Schematic file:
Personal CAD Systems, Inc.
PC-CAPS  Database file version : 2.08
Database saved as : sheet1.sch
Dec. 6, 1997         4:54 p.m
PCB file:
PC-CARDS Database file version : 2.08
Database saved as : place2.pcb
Nov. 24, 1997         9:34 p.m.
I have a copy of P-CAD v8.50 running in Virtualbox, which loads up the schematics no problems, but the PCB editor: PCCARDS requires a security dongle to load.
Does anyone have any suggestions to how I import the files into Altium or other ECAD system.
Regards,
Derek
Regards,
Derek
Offline thm_w
  • Non-expert
Re: Altium Designer 21 Import P-Cad Files
« Reply #2 on: March 11, 2023, 10:11:53 am »
Thanks for the reply, I have tried the Altium Designer Import Wizard, but the P-CAD Schematic and PCB files are not recognised, I asked Altium Technical Support, who also failed with the same results.
Maybe I will have to load the data files into next version of P-Cad, then save it till P-CAD 2002 or 2006 can load it.
Not sure how to do this, I will have search for old PCB software.
Regards,
Derek
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: March 11, 2023, 10:17:52 am »
I run P-CAD2006 if you want to try the load/save-as method mentioned on the Altium page
Day Job: Mostly LEDs
Online mk_
  • Country: at
« Reply #4 on: March 11, 2023, 10:31:25 am »
Schematic file:
PCB file:
That`s PCAD DOS and really old...
Try to load your files with PCAD2006 (i still use this version) and then move to Altium (can`t help you with that)
PM when I should give it a try for PCAD8.5 (DOS) to PCAD2006 (Win)
Good luck
