Author Topic: Graphic Import  (Read 6325 times)
Offline Tony R
Graphic Import
« on: January 31, 2012, 02:26:09 pm »
Hello, I know it is possible to import a graphic into Altium for use of a silk screen. I have checked the online documentation which told me to use the scripts found in the example directory, but some how the scripts are not there. Here is what i want to import into altium, I am using Altium 10.
Where can i get these scripts to covert this into either lines or solid regions? or is there another way?
Tony R.
Computer Engineering Student
Focus: Embedded Assembly Programming, Realtime Systems,  IEEE Student Member
Offline joelby
Re: Graphic Import
« Reply #1 on: January 31, 2012, 02:37:09 pm »
Have a look at this thread.
« Last Edit: February 01, 2012, 01:35:17 am by joelby »
Offline Psi
Offline joelby
Re: Graphic Import
« Reply #3 on: February 01, 2012, 01:35:54 am »
Oops! Thanks. The forum mangles URLs with an extra http if you put it in quotes.
