Author Topic: Problem inserting keep out track in weird board shape PCB.  (Read 2314 times)
Offline FullRock66Topic starter
  • Country: cl
« on: June 20, 2017, 08:49:36 pm »
The problem that has been generated is that I am innovating with non-common forms of PCB (for me at least), in this case it is a form of leaf of tree, but I can not put a keep out track on the edge of the PCB, is possible? I leave a photo so that they can see of those that I speak.  |O |O
Offline David_AVD
Re: Problem inserting keep out track in weird board shape PCB.
« Reply #1 on: June 21, 2017, 04:28:15 am »
How did you do the board shape?  Can you use the same process for the keep-out?
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: June 21, 2017, 05:34:34 am »
Design - Board Shape - Primitives From Outline
You can also select primitives and create the shape from that.
Seven Transistor Labs, LLC
  • Country: cl
« Reply #3 on: June 22, 2017, 09:52:18 pm »
The truth was I did with the base of a circle, using the PCB Board Wizard, it was simple after trying 1000 times, but the problem is that I can not put a keep out track in the contour of the PCB, on a rectangular PCB it is very Simple, but in this particular case do not do it, maybe it is not possible.
  • Country: cl
« Reply #4 on: June 22, 2017, 09:54:43 pm »
What good information, put your hands to see how it goes and I tell you, thanks.
  :scared: :scared: :scared: :clap: :clap: :clap:
  • Country: cl
« Reply #5 on: June 22, 2017, 10:04:07 pm »
Dear T3sl4co1l .... Tu eres el mejor, eso era todo lo que necesitaba, has sido mi salvación, espero poder devolverte la mano mi amigo. :clap: :clap: :clap: :-+ :-+ :-+ :-+ Thanks so much!
Online T3sl4co1l
« Reply #6 on: June 23, 2017, 06:39:21 am »
Gracias :)
