Author Topic: Can you do it in AD?  (Read 1351 times)
Offline olkipukkiTopic starter
« on: January 15, 2021, 12:42:29 pm »
After years of use Altium, still a lot of things to learn to improve own efficiency...
Can you do similar in Altium?  :-//
OrCAD Capture Autowire
https://youtu.be/L5f2zUt18B4?t=45
Offline EE-digger
Re: Can you do it in AD?
« Reply #1 on: January 16, 2021, 04:46:17 am »
CS has auto wire so I'm sure AD also does.
Start a wire at a pin, use shift+space or space to toggle end and corner modes and TAB to enter auto wire mode.  A small dialog box asks for a time limit for routing and also a L (low) to H (high) chance of cutting something.
In auto wire mode, the wire will be a rubber band that is heavily dotted.  Click on the destination and it will route.
It's a bit tricky and just took me about 10 minutes to get it right.
It would be nice if documentation was better but that's why we have forums  8)
