I was going to ask if this is possible but after some routing around on Google I found this:
It would appear these are boards where the designer has utilised the PCB manufacture process to produce effectively some glorified coasters
this is not exactly my intention but the theory is the same.
I wanted to know if it is possible to import JPGs (vectors) into altium to be used for effectively tracks. Well not tracks but what would normally form the track ie the metal bit to make crazy designs such as this on your board.
Why do i want to do this? I was given the inspiration by one of daves videos on youtube discussing using the back of a PCB as the panel. its his micro-amp product. I then thought could you take this one step further and use the tracks to form instrument gauges etc?
if you can this would be cool. I would really value any comments about the feasibility of this idea?
When I say instrument gauge just to be clear i mean something like this using PCB tracks.
can altium potentially do this with imported files?
Inkscape with the inkscape scale generator is a beautiful way to make these gauge designs in vectors.
