Author Topic: How to connect a remote SVN repo to altium designer?  (Read 9595 times)
Offline m4l490nTopic starter
« on: October 20, 2015, 12:50:30 am »
Hello everybody.
I have a repository hosted in assembla. I need to be able to access this repository from altium in order to version control a design I have and share it with a friend that is helping me in the design. Every time I want to configure AD13 to connect to a repository it does not let me to add the "/" character to the remote repo URL. I don't know how am I supposed to configure AD13 to be able to work this way.
Any suggestions?
Offline free_electron
    • SiliconValleyGarage
Re: How to connect a remote SVN repo to altium designer?
« Reply #1 on: October 20, 2015, 01:30:59 am »
Is that an svn server ? otherwise no-go
« Reply #2 on: October 20, 2015, 01:37:28 am »
Install tortoisesvn on your computer. Create a local Repository.
Checkout the files from Assembla into your local repository.
Once you have the local files open them in Altium. Altium will detect that the files belong to an SVN and will automatically connect.
you can now perform checkin checkout directly from inside altium
« Reply #3 on: October 23, 2015, 01:31:02 am »
Thanks for helping, but, it didn't work  :'(
Do you know how to configure Altium Designer to work with remote repositories?
Regards.
Offline Bassman59
  • Yes, I do this for a living
« Reply #4 on: October 24, 2015, 04:15:21 am »
Why not just use TortoiseSVN for the Subversion stuff and do only the board design in Altium?
Offline Gribo
« Reply #5 on: October 24, 2015, 07:05:59 pm »
When Altium designer is connected to the SVN repo, it shows the status of each file under version control (Green = OK, Red = different from the one in the repository).
To connect to a remote SVN server, you need to input the server's URL and connection method (HTTP, HTTPS, SVN, file or FTP). Altium's client is old and is not supported in the current version of the SVN server, so you need to use a newer client, ToroiseSVN is an excellent choice and can be specified in the Data management/Version control option tab in Altium designer's preferences.
I am available for freelance work.
« Reply #6 on: October 24, 2015, 09:43:32 pm »
If you install tortoisesvn altium will interact through that with the svn server. It works perfectly fine.
Offline ondo
« Reply #7 on: September 02, 2016, 01:04:09 pm »
Since it took me a while to solve figure this out, and somebody else might be in the same situation:
- You'll need to install svn (easiest way is by installing tortoiseSVN, and selecting cmd line tools).
- Then go to version control and make sure altium is using your svn.exe, and not the inbuild one (select external and fill the path).
The configuration you'll need:
- Name: Whatever you like
- Default chekout path: Location in your PC to store files
- Method: https
- Server: subversion.assembla.com
- Repository subfolder: /svn/yourRepositoryName
Fill username and password too if needed.
Offline aklimi
« Reply #8 on: May 08, 2018, 05:20:47 am »
