I've attached two screen shots of a part in the part editor and on a board. The part displays correctly in the editor however when I add it to a board it just displays a box in roughly the same size of the part. I've had this happen before, however it sort of cleared itself up after awhile. I'd like to try to find a fix to it though because on this design it's causing false errors. Thanks.
