Author Topic: How to highlight nets and remove/add layers in Altium Free viewer? (21.0.0.235)  (Read 932 times)
Offline ocsetTopic starter
How to highlight nets and quickly remove/add layers in Altium free viewer?...in PCB.
At the moment i have to remove/add layers by a number of clicks for each layer.....is there not a table you can get which shows all the layers,
then you can quickly uncheck/check a box to remove/add that layer?
Also, i have the PCB panel open, and i am clicking on the net name, but it is not highlighting it in the PCB. Please advise?
Also,  the Altium free viewer constantly hangs and “blue circles”  when running on my Acer aspire 3 laptop. I am using windows 10.
The Altium website does not say what is the system requirements for the free viewer. Do you know what it is?
(the full blown purchased  Altium designer needs an intel i5 processor or equivalent, which goes up to 4.2GHz…….my Acer aspire 3 laptop only goes up to 3.2GHz….could this be the problem?)
« Last Edit: January 19, 2021, 11:19:21 am by treez »
Offline BitsnBytes
  • Country: pk
To highlight the any net press CTRL and left click on any SMD or through hole pad associated to the net.
To add / remove layer you can use short key SHIFT+S.
In the bottom pane of Altium you will see LS (Layer Stack) on left corner right click on it to enable / disable any layer.
Regards
printf("Respect");
The following users thanked this post: ocset
