Author Topic: Altium ActiveRoute  (Read 1516 times)
Offline cjurczakTopic starter
Altium ActiveRoute
« on: January 08, 2019, 06:51:44 pm »
I hope not to cause the zealots and trolls to riot, but does anyone use ActiveRoute?  I use it occasionally to route point to point monotonous portions of interconnects.  I only use it on a single layer, and have been reasonably happy with the results.  After not having used it in awhile, I have been having some issues.  ActiveRoute will complete, but the portion of tracks it ran will be full of DRC violations.  I have the Track-Track Space set to Rule, but I don't see any other settings that could be the problem.  I am recently ugraded from 18 to 19, but the same problem seems to occur in 19.
If anyone might have any insight into how I am using the wrong, or what I can do to make sure the results of ActiveRoute are within DRC constraints it would be appreciated.
