Author Topic: hierarchical port being automatically resized?  (Read 1127 times)
Offline incfTopic starter
  • ASCII > UTF8
« on: January 28, 2025, 02:52:53 pm »
Does anyone know how to prevent hierarchical ports from being automatically resized? It can cause connectivity issues if the wrong end of the port gets moved as often happens.
In the attached example, A hierarchical block called "MEAS_BAT1" contains a hierarchical block called "COMP" and this has a port/named net called "BALBLE"
The port inside COMP gets resized to be as wide a the string "BALBLE_MEAS_BAT1" when performing various actions like clicking the tabs at the bottom of the schematic editor screen
Place the port in the editor tab, it's the size I'd like it to be
Click the tab for instance COMP1 (located inside MEAS_BAT1)
Go back to the editor tab and it is resized
« Last Edit: January 28, 2025, 02:57:34 pm by incf »
Test
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: hierarchical port being automatically resized?
« Reply #1 on: February 07, 2025, 12:05:54 am »
Make sure you uncheck ports. I would recommend Net Labels too.
“They Don’t Think It Be Like It Is, But It Do”
  • ASCII > UTF8
« Reply #2 on: February 07, 2025, 12:23:35 am »
Thank you.
I didn't even know those options existed - will try. (Although, I do wonder if it will have any other side effects besides just displaying different text)
sidenote: I reported the bug a while a ago through the 'proper channels' and surprisingly got a response from what appear to be dev/quality people.
« Last Edit: February 07, 2025, 12:54:19 am by incf »
Test
Offline Pseudobyte
« Reply #3 on: February 11, 2025, 11:01:07 pm »
It is purely a visual thing for the editor. From what I remember, you have another similar set of options for the outjob for the schematic prints. I would agree that the behavior still seems like a bug. I think i'd prefer to leave those options on, but have the compiled net name in parenthesis beneath the port.
If you are trying to change the multichannel/hierarchical naming you need to do that in the project options.
  • ASCII > UTF8
« Reply #4 on: February 11, 2025, 11:11:01 pm »
The bug moves and disconnects ports in some instances, and messed up my board - which is how I got the dev teams attention
« Last Edit: February 11, 2025, 11:26:21 pm by incf »
Test
Offline Pseudobyte
« Reply #5 on: February 13, 2025, 11:35:08 pm »
I was referring to the options themselves being visual. I agree the behavior is unexpected, buggy, and dangerous.
