I would use sub-sheets, or whatever they're called.
Main sheet contains 10 references to the "column" sheet using a sheet symbol, and the column sheet contains 10 LEDs (or, if the circuitry is complex enough, the column sheet could contain 10 "pixel" sheets).
Still a little bit of wiring, but 20 objects is a lot better than 100!
