Author Topic: Placing a whole in Altium!  (Read 8092 times)
Offline sean87Topic starter
  • EE WannaBee
    • EMBEDONIX
« on: January 10, 2012, 10:13:48 am »
Hi all,
I wonder if you can give me some tips about Altium Designer 10.
I am trying to design a simple PCB that contains 20 Resistors. The goal is to have this 20 resistors in paralel, fed from a +12V line (there is no return path or ground needed) and connect each resistor to a pin of a 20 pin header connector. In the attached image you can see what I have done already (Well not much yet!)
So my question is, how can I place a one whole (just think it as a one pin header) that I can later solder my +12V line and then connect this line to all resistors? so simply, how can I just add a whole that can be used to solder a wire in it later?
My other questions is, The resistors I am using are just normal resistors that fit in a prototyping bread board. I am using Axial 0.3 in Altium. Is that the right choice?
Thanks.
EMBEDONIX - Embedded Systems, Linux and good stuff!
Offline Armin_Balija
Re: Placing a whole in Altium!
« Reply #1 on: January 10, 2012, 12:36:51 pm »
I assume you can place a via and place a track leading to the input pins on your header. Then obvious connect your header to the resistors.
Offline Psi
« Reply #2 on: January 10, 2012, 03:19:43 pm »
At the bottom of the "miscellaneous connections" library there is a "socket" which is basically just one through hole pin.
That's what i use when i need a single pin.
(Note: it maybe different in your newer version of Altium )
I like to use Axial 0.4 because Axial 0.3 can get a bit tight.
Axial 0.3 will still work though, you just have to bend the legs really close to the resistor.
« Last Edit: January 10, 2012, 03:23:09 pm by Psi »
« Reply #3 on: January 10, 2012, 09:17:11 pm »
Totally misunderstood what he was saying. Now that I see the socket it makes perfect sense. I wonder how many things in Altium I've never come across.
Offline Psi
« Reply #4 on: January 10, 2012, 11:13:34 pm »
lots :)
Only yesterday i found the option to "find similar objects" which lets you select all objects that meet the specs you want.
Before then i was having to hold Ctrl down and click each pad one at a time :(
Also, Shift + Ctrl + D is very useful. It aligns the selected component to the grid.
I dunno how but often things get out of alignment and two components will move in the correct grid step but one is offset by some amount.
That shortcut will reset the object to the grid.
« Last Edit: January 10, 2012, 11:16:13 pm by Psi »
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #5 on: January 21, 2012, 05:24:52 am »
There are many Eagle features I never knew about until I read through the manual! It's there for a reason. Use it to learn and not only consult it when you have problems  ;)
Offline IanB
« Reply #6 on: January 21, 2012, 06:07:09 pm »
I was going to ask, "Placing a whole what?" as it keeps catching my eye in the  topic list  :)
However, I see English is not your first language so you are forgiven  ;)
(whole - heel and hole - gat are the translations I think)
