Author Topic: Install all libraries within a directory?  (Read 2562 times)
Offline Pack34Topic starter
« on: November 27, 2017, 03:45:28 pm »
I've been on a librarian binge and created >50 libraries.
Is there a way for someone to install these in bulk on their computer? Or is it strictly a manual process?
Is there a way to script this?
Offline Psi
Re: Install all libraries within a directory?
« Reply #1 on: November 28, 2017, 05:07:26 am »
I think there is a library group or package.  But im not at my pc to check.
When altium used to have a large part library, before they went to the vault, there was like a main "national semi vreg library" for a random example. It contained many sublibraries
« Last Edit: November 28, 2017, 05:11:04 am by Psi »
Offline Fire Doger
  • Stefanos
« Reply #2 on: November 28, 2017, 08:01:10 am »
I have installed only libraries that I use on every project (resistor, caps, etc)
For the rest I am using search on the folder which contains all my libraries
