Being new-ish to altium i'm still learning some things about how it works, so if anyone has some pointers for me, it would be great.
I have created a project that has 64 "outputs", so using channels seemed like a good idea.
My Main Sheet has "four" sheet references.. That sheet that is referenced, contains a further sheet references.
That all works fine..
When i import components into my PCB document, I end up with Lots and Lots of rooms, ( ~190 in this project ), which is correct, but I'm wondering if there is anyway of 'grouping' or nesting rooms in the pcb document.
I have 8 rooms containing "output protectors", which together with 4 output drivers form a "bank" of 4 outputs ( 8 protectors per output ) .. I then have 4 banks..
I would be great if i could somehow route each room once, then bring those rooms together somehow to a "bank-room" which i would then copy the format to the other ones..
Right now it seems i can only get the advantage of routing a single room, but not in how i bring all the rooms together..
I'm sure that this problem has been faced by others.. Any help greatly appreciated.
