Author Topic: Double Precision Shortcut in the Routing Grid?  (Read 3649 times)
Offline x18Topic starter
« on: November 17, 2011, 04:21:45 pm »
I'm quite new to Altium. I used EAGLE before. In EAGLE I could change my grid resolution by pressing the [ALT]-Key and by typing "grid" in the commandline I can change what the resolution should be after pressing [ALT]. Is there a shortcut like this in Altium and where can I define what the resolution should be?
greetings.
Re: Double Precision Shortcut in the Routing Grid?
« Reply #1 on: November 18, 2011, 11:29:11 am »
I found a solution to this problem. By pressing [G] I can choose the grid resolution in the menu that pops up.
