Author Topic: How to route traces without losing the sight of everything [SOLVED]  (Read 1256 times)
Offline Lucky-LukaTopic starter
Hi all
When I try to route traces everything turns black except the initial and final pad. How can I see everything?
Thanks
« Last Edit: February 17, 2021, 09:09:39 pm by Lucky-Luka »
Memento audere semper.
Offline ajb
Re: How to route traces without losing the sight of everything
« Reply #1 on: February 17, 2021, 06:56:08 pm »
This is controlled by the mask/dim/highlight sliders on the "View Options" tab of the "View Configuration" Panel.  There may also be a setting that controls what happens when you're in interactive routing, I don't remember and didn't immediately see anything in settings
The following users thanked this post: Lucky-Luka
