Author Topic: Output File and CAMtastic  (Read 2190 times)
Offline slowaudioTopic starter
« on: February 17, 2014, 06:21:42 pm »
I've recently upgraded from version 10 to version 14 and have noticed something different when I'm outputting my Gerbers. I've created an OUTJOB file and have setup fabrication outputs to generate the appropriate Gerbers and NC Drills. In previous versions after I'd generate the content a new CAM file would be created and I could go in check to make sure the Gerbers had been generated appropriately. However it's not doing that anymore.
This is the first project I've started in 14. However when I open a project created from a previous version and generate content again, the a new CAM file gets created. Is there a project specific setting I've missed?
Offline free_electron
    • SiliconValleyGarage
Re: Output File and CAMtastic
« Reply #1 on: February 17, 2014, 07:29:19 pm »
there is an option somewhere "open document after creation"
« Reply #2 on: February 17, 2014, 07:39:59 pm »
it almost seems like the CAM file isn't being created. I don't see it anywhere in the working directory.
