Author Topic: Holes are shifted  (Read 3646 times)
Offline Marek9011Topic starter
Holes are shifted
« on: October 08, 2013, 01:30:22 pm »
Hello,
I printed my pcb and i got this:
http://marek.php5.sk/wp-content/uploads/2013/10/offset.png
You can see that holes of U2 is shifted. Holes in right looks ok.
My workflow is:
-generate print preview
-set up colors, layers, scale...
-print with pdf printer
The colored print is also shifted. When i generate pdf with "output job file" offset is also there. U2 on image is MAX232 which i found in standard library "TI Interface Line Transceiver.IntLib". Holes in parts that i drawed myself are also shifted
...any advice is appreciated
« Last Edit: October 08, 2013, 01:32:41 pm by Marek9011 »
Offline Psi
Re: Holes are shifted
« Reply #1 on: October 08, 2013, 01:38:34 pm »
That really is quite weird.
Only thing i can think of is some setting or shortcut has been switched on by accident.
i have no idea what setting that is though.
« Last Edit: October 08, 2013, 01:40:27 pm by Psi »
« Reply #2 on: October 08, 2013, 02:23:12 pm »
a more demostrative image:
http://marek.php5.sk/wp-content/uploads/2013/10/resistor_offset.png
Is there any other method to "wipe" holes? except:
http://marek.php5.sk/wp-content/uploads/2013/10/dialog.png
I managed to get this result:
http://marek.php5.sk/wp-content/uploads/2013/10/output.png
still not perfect, pad on right have dimension 50x100mils, hole is 50mils.
my solution: In windows uninstall a program>altium designer>uninstall>remove preferences
Also changing imperial/metric units schould be avoided, adobe reader might get part on im-perfectance.
...do you guys get same result when you place same pad as i?
« Last Edit: October 08, 2013, 04:01:33 pm by Marek9011 »
Offline owiecc
    • Google scholar profile
« Reply #3 on: October 12, 2013, 08:50:36 pm »
Try printing it on paper directly. Maybe your pdf printer does some "optimizations". What softwere do you use to generate pdfs? What about gerber files? do they look ok?
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: October 12, 2013, 11:12:13 pm »
this looks like a problem in pdf .
