Author Topic: Altium component rotate as in Eagle  (Read 3278 times)
Offline yoopeeTopic starter
  • Country: cz
« on: April 30, 2017, 10:13:53 am »
hello,
I'm moving from Eagle to Altium and I'm trying to set the Altium's user interface similary to Eagle's. I've set the zoom command for using with mouse wheel correctly, but I have a problem to set rotate component command. In Eagle I was using right mouse click to component rotate.
Is it possible to set this command in the same way as in Eagle, please? Because in Altium's Edit-Move-Rotate selection I can only choose keyboard shortcuts...
Thanks,
Peter
Offline ebclr
Re: Altium component rotate as in Eagle
« Reply #1 on: April 30, 2017, 10:28:50 am »
When moving or dragging selected objects, click Space on keyboard
  • Country: cz
« Reply #2 on: April 30, 2017, 10:31:21 am »
yes, I know this command. But it is posibble to set the UI for component rotate with right mouse click only?
Offline ebclr
« Reply #3 on: April 30, 2017, 10:34:20 am »
I would suggest forgetting Eagle days, and just accept the Altium way, Or come back to eagle, isn't a good idea to emulate eagle on Altium
Offline DerekG
  • Country: nf
« Reply #4 on: April 30, 2017, 11:10:48 am »
No, in the mouse button matrix, this is not an option.
Pressing the space bar whilst holding or dragging the component is the fastest way to rotate the component in increments of 90 degrees.
I also sat between Elvis & Bigfoot on the UFO.
Online dave_k
« Reply #5 on: April 30, 2017, 11:12:16 am »
In addition to this, while clicking/dragging a component pressing X or Y will flip the part.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: April 30, 2017, 01:38:36 pm »
There's very little (if any?) that can be changed about the keys used in modes.
Menu shortcuts can be edited, though.
Seven Transistor Labs, LLC
Offline Pack34
« Reply #7 on: April 30, 2017, 10:04:40 pm »
If you're switching back and forth, you could always get an "MMO" mouse and program the buttons. You can have multiple modes for the mouse (EAGLE, Altium, etc) then just map the single button to the command for the specific program.
On the Logitech mouse below you could have G9 set to SPACEBAR in Profile1 and RIGHT-CLICK in Profile2.
http://gaming.logitech.com/en-us/product/g600-mmo-gaming-mouse
Offline julianhigginson
« Reply #8 on: April 30, 2017, 10:59:02 pm »
altium works very differently to eagle... even if you match some buttons and shortcuts, the whole way the functions they are tied to relate to each other is different.
also, if you ever need to use someone else's altium install in the future you're going to have a terrible time.
suggest you just deal with the differences and learn the new tool, as frustrating as it must seem right now.
The following users thanked this post: ahbushnell
Offline Pitrsek
  • Country: cz
« Reply #9 on: May 01, 2017, 12:50:24 pm »
+1
