Author Topic: I have some pads which overlap the edge of the board  (Read 1524 times)
Offline snoopyTopic starter
    • Analog Precision
« on: October 31, 2018, 12:10:36 pm »
I have some screw holes which have a pad that overlaps the edge of the board and is giving me an online drc error with a keepout barrier I use around the board. I would like to include a pullback using a keepout like you can do with the polygon fills. Is this possible to do with pads or any other copper that is to close to the edge of the board or do you have to edit the gerber files to do this ?
cheers
david
Offline ajb
Re: I have some pads which overlap the edge of the board
« Reply #1 on: October 31, 2018, 03:19:28 pm »
Pads are primitives, so I don't think there's any way to carve them up.
Does the hole intersect the edge?
If not, you can simply set the pad size to a minimum and then draw the pad shape as a polygon with mask expansion enabled.  Unmasked polygons with a pad in the middle to establish electrical connection to the schematic symbol are the way you get arbitrary pad shapes in Altium anyway.
If so, and you don't need it plated, you could just draw the pad shape as a polygon and make the part circle of the drill part of the board outline.  If you need it plated, you could either ignore the error and call out your intentions to the PCB fab, or draw the polygon and tell the fab they need to edge plate the appropriate area.
    • Analog Precision
« Reply #2 on: November 01, 2018, 03:47:47 am »
yes the holes clear the edge of the board. It's only the pads that extend out to far.
cheers
