Author Topic: Automatically Assign Unused Component Part In Repeat Sheet?  (Read 1569 times)
Offline petersanchTopic starter
I want to repeat a sheet twice. The sheet uses 1 transistor from a package that contains 2 transistors (schematic component has 2 parts which are the same but with different pin numbers).
Is there a way to annotate the schematics so that the unused transistor is automatically assigned and used for the second instance of the sheet?
Cheers
Offline free_electron
    • SiliconValleyGarage
Re: Automatically Assign Unused Component Part In Repeat Sheet?
« Reply #1 on: June 17, 2021, 08:15:21 pm »
no. that doesn't work.
« Reply #2 on: June 18, 2021, 02:40:57 am »
Thanks. Whats the best way to do this for repeated sheets?
« Reply #3 on: June 18, 2021, 03:38:15 am »
build the circuit as a 2 channel that you repeat
