Author Topic: Altium FPC bending / bending line contains strange graphical artifacts  (Read 1788 times)
Offline smoothVTerTopic starter
I have a FPC wiring harness I've designed in AD16:
I define a bending line, and when I hit the '5' key the FPC bends but contains strange artifacts, as if bubble gum is being stretched between the edges of the FPC:
Anyone have an idea as to how to fix this and remove these artifacts?   Could it be some misaligned layer in my stack?
Offline DutchGert
Re: Altium FPC bending / bending line contains strange graphical artifacts
« Reply #1 on: September 26, 2017, 12:52:57 pm »
You also need to set the bending radius :)
