Author Topic: How do i design guard ring in PCB?  (Read 6039 times)
Offline behzad63Topic starter
« on: October 10, 2016, 04:13:08 am »
Hi dear
I want to know how do i design guard ring in PCB?
Thanks
Offline T3sl4co1l
    • Seven Transistor Labs
Re: How do i design guard ring in PCB?
« Reply #1 on: October 10, 2016, 06:14:10 am »
Place the copper shapes as needed, then select them and apply the "solder mask opening" setting in the Inspector Panel.
Seven Transistor Labs, LLC
Offline tszaboo
« Reply #2 on: October 10, 2016, 12:00:24 pm »
You should place lines instead of tracks. Put it on the top/bottom copper and the soldermask. Tracks might work, but make sure to turn off "automatically remove loops". You probably know that the guard ring is only working, if the voltage difference between the senistive node  (*pcb junction) and the guard node are the same voltage. So the guard ring is driven by something, like an opamp. I usually use the "VCC power port" to name the guard ring.
Offline ali_asadzadeh
« Reply #3 on: October 13, 2016, 04:19:50 pm »
Thanks, how a floating copper loop protects the circuit? I mean what's the purpose of the guard ring and how does it help us?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: October 13, 2016, 06:14:26 pm »
guard ring is not floating, usually its connected to the buffer of the high impedance signal input. the purpose is to avoid any stray different signal from surrounding got injected into the high impedance node.
Offline T3sl4co1l
« Reply #5 on: October 14, 2016, 06:20:22 am »
Do you not know... have you not read about what a guard ring is?  You must've read something or you wouldn't know it's a thing that exists!  Surely if you have understood its purpose, you would also understand where to apply it... ???
