Author Topic: A18- 3D Body Opacity 0%-Question  (Read 1502 times)
Offline generic_usernameTopic starter
  • Country: at
« on: July 08, 2019, 07:09:49 am »
Hello everyone,
I'm currently verifying my layout with a 3D Body for Assembly.
(Quick Note, the PCB will be mounted on a flat plane hence the 3D verification)
So I imported a Step Model of my mounting plane as a generic 3D Body and aligned the PCB with it. looks all fine and dandy but
I don't always want to see the 3D Body when layouting so I have 2 choices.
1st I could hide the mechanical Layer on which the 3D Body is placed.
2nd I can set the opacity of the 3D Body to 0% as it apperantly hides it even in 2D Mode, the Problem with this method is that I have no clue on how to make it appear again if needed as I can't click on it anymore, is there a List of imported 3D Models or something else?
For the time beeing I'll hide the mechanical layer so not a problem for me but would be neat to know if there's an option like this.
cheers.
I always need 3 attempts to plug in a USB connector
Offline enz
Re: A18- 3D Body Opacity 0%-Question
« Reply #1 on: July 08, 2019, 07:22:35 am »
Yes there is. This is for AD19, but I'm pretty sure that it is the same for AD18:
- Activate the PCB panel
- At the top drop down list, select "3D Models"
- In the middle of the panel select "Free Models"
- At the bottom now you have a list of all free models in the pcb. At the end of each line you'll find a blue icon: Clicking on it will cycle through the opacity levels in steps of 25%.
Hope that helps.
Best regards,
Martin
  • Country: at
« Reply #2 on: July 08, 2019, 08:37:52 am »
Worked for AD 18 just fine.
Great Thank you
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: July 09, 2019, 03:57:51 am »
You'll also find them on the PCB List (view only 3D Component Bodies, sort by opacity) and by query (although in the past, querying 3DComponentBodys hasn't been very effective so YMMV).
Seven Transistor Labs, LLC
