Author Topic: How to get circular ground pour?  (Read 19222 times)
Offline Robert.AdamsTopic starter
  • Automotive Hardware Engineer
« on: July 01, 2014, 10:59:10 pm »
Hello,
I've been trying this for a day or so and I can't seem to get a circular ground pour in Altium 14.3.  I've created a circle as an online and did convert to polygon from selected primitives.  After going to the polygon manager and trying to pour the polygon I get a ground trace that runs along my other traces instead of a consistent pour.  What am I doing wrong?!?
Offline ludzinc
    • My Misadventures In Engineering
Re: How to get circular ground pour?
« Reply #1 on: July 01, 2014, 11:09:20 pm »
I've been caught by this one before.
When you convert from selected primitives, the 'Fill Mode' is set to 'None - Outlines Only'.
Change the Fill Mode to Solid (see attached).
« Reply #2 on: July 01, 2014, 11:12:00 pm »
Thank you so much!  Ugh, I should've caught that.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: July 01, 2014, 11:41:38 pm »
why so complicated ?
simply draw a circle on the layer you want to pour. in the inspector : check the box that says : 'keepout'
pour a simply rectangular plane and checkk 'remove dead copper'
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: July 02, 2014, 03:48:03 am »
Personally, I'd draw a rough polygon around the outline and set the clearance to keep-out at something ridiculous (as it seems you're going for a fairly large pullback in this case).  Pretty much what f_e said.
Seven Transistor Labs, LLC
Offline ludzinc
« Reply #5 on: July 02, 2014, 04:38:23 am »
You say Po-tay-toe I say right click convert, don't draw extra rectangle.
« Reply #6 on: July 02, 2014, 05:13:18 am »
i can go back and alter shape , you can;t ...
Offline ludzinc
« Reply #7 on: July 02, 2014, 06:10:15 am »
Wha?
I reshape my outline and right click again.  Simple.
There's often more than one way to do something - doesn't mean mine is better than yours.  I don't like your's as the neat freak in me hates Rooms / Polygons that extend past a board's edge, your workflow suits you better.
The Gerbers would be the same in both cases (all other things being equal)....
Offline will9twl
  • Country: sg
    • Bazinga - Your technology partner. From ideas to gadgets.
« Reply #8 on: August 05, 2015, 07:05:12 am »
tried what ludzinc suggested
pretty easy indeed! thanks! :-+
I sell on Tindie"width="200" height="55
Offline sweetbug01
  • Country: in
« Reply #9 on: July 29, 2020, 11:43:34 am »
Place menu -> Polygon Pour
press tab and select ground in net dropdown, check (remove dead copper) checkbox from property
left click and drag (+) cursor over round pcb to pour layer
double click right mouse button.
