Author Topic: Why is Altium viewer so slow?  (Read 1168 times)
Offline FaringdonTopic starter
« on: November 19, 2022, 06:36:33 pm »
Why is altium viewer so slow when clicking layers on and off in "view configuration".
Can we improve it?
I have windows 10 and 8MB RAM.
Its the latest version of Altium viewer
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Bud
Re: Why is Altium viewer so slow?
« Reply #1 on: November 19, 2022, 06:42:39 pm »
I guess you mean 8GB. That is probably just enough to run the OS. You should upgrade to 16GB. I have 32GB but it is a bit of overkill for Altium alone.
Edit: just noticed you are talking about the viewer version. Not sure about it.
The following users thanked this post: Faringdon
Offline PlainName
  • Country: va
« Reply #2 on: November 20, 2022, 06:27:59 pm »
I have 32GB but made 5GB of it int a RAM disk onto which I shove the system temp folder. Reason being I don't want my SSD finite-lifetime writes being taken up with temporary system (and other) files.
Since doing that I now use it as my general download folder too - anything not moved off to permanent storage at the end of the data doesn't matter, and it doesn't steadily accumulate dross.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #3 on: November 20, 2022, 11:01:35 pm »
What sort of video card do you have?
Over the years Altium have become more GPU intensive, like if you look at their recommended requirements they ask for GTX 1060/Radeon RX 470 and above
https://www.altium.com/documentation/altium-designer/system-requirements
