I recently moved from Capture to Altium, and while most things are a vast improvement, the one thing I miss is the intersheet references. The port cross reference report in Altium is similar, but it shows the entire filename of the schematic sheet, which looks really confusing on a sheet with a lot of ports, and tends to run off the page. All I want is the sheet number, surrounded by brackets -- does anyone know if there is a way to customize the port cross reference report to do this?
