Author Topic: Trace and pad.... same net..... but poor connection  (Read 1571 times)
Offline Mikekoz13Topic starter
« on: November 04, 2015, 05:07:58 pm »
Hi all-
I have a trace with net XY and it runs very close to a pad with the same net of XY. The trace literally barely grazes the pad. This does not show up as a disconnect when running design rule check but it is an extremely poor, unreliable connection. The design clearance rule is set to "Different Nets" so there is no clearance error. If I change the rule to "Same Net" I get a ton of errors (obviously).
How do I set up a rule to flag this? I've played around with the rules with no luck.
Thanks for any help.
Offline ConKbot
Re: Trace and pad.... same net..... but poor connection
« Reply #1 on: November 07, 2015, 05:05:16 pm »
http://www.newelectronics.co.uk/electronics-videos/altium-design-secret-23-advanced-setting-of-the-width-rule/62909/   :-+
AV sync is a bit weird in the video, but you dont see a person talking, so its not that bad.
