Author Topic: Print file displaying sizes  (Read 2300 times)
Offline danskuTopic starter
  • I make things
    • Personal Blog
« on: August 23, 2016, 09:28:01 am »
Hi all, I am trying to generate a file displaying distances and sizes in Altium, similar to this one
How can I build the same in Altium?
Thank you :)
Online T3sl4co1l
    • Seven Transistor Labs
Re: Print file displaying sizes
« Reply #1 on: August 23, 2016, 01:35:05 pm »
P, D, L (Place, Dimension, Linear), and the other kinds.
Usually, you'll place dimensions on the Drill Drawing, or a mechanical layer.  Personally, I prefer to put the mechanical outline (with dimensions, holes, board outline and any significant features) on Mechanical 2.
You should read up on geometric dimensioning, and drafting, too, if you don't know how they work.  It's easy to miss dimensions or put in ridiculous tolerances if you aren't thinking about it.
Seven Transistor Labs, LLC
