Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Can altium open/convert Mentor PADS schematic
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Can altium open/convert Mentor PADS schematic (Read 4834 times)
violet221
Newbie
Country:
on:
August 05, 2018, 09:49:44 pm »
Hello!
I'm struggling with an issue that I had a Mentor PADS schematic file and I need to import it to Eagle, but this can't be done directly, so i need schematic in Altium format which I can import with Eagle script. Unfortunately, I don't have Altium to try open this file, can someone can try open this file with Altium and try to save this as Altium schematic file(possibly ASCII format can be imported with eagle). I really need to do this conversion but all my tries are a fault for this moment so I'm looking for helping hand
. I'm attaching normal PADS .sch and ASCII (.txt)which I exported from PADS, because I don't know which Altium can import
pads sch:
http://s000.tinyupload.com/?file_id=99564504247722666624
pads ASCII:
http://s000.tinyupload.com/?file_id=89986535492763662281
I used tinyupload because .sch files cannot be uploaded as an attachment
Greetings
Logged
mengfei
Regular Contributor
Country:
Re: Can altium open/convert Mentor PADS schematic
Reply #1 on:
August 08, 2018, 01:51:03 am »
I think pads file should be saved as *.asc & not *.txt file for altium to open it.
I have a file.asc & altium can open it.
Logged
violet221
violet221
Newbie
Country:
Reply #2 on:
August 26, 2018, 11:34:02 am »
Hello Mengfei
Thanks for Your answer, I just exported .asc file from Pads, is it possible for You Mengfei to try open this file and then save it in altium format ?
http://s000.tinyupload.com/?file_id=19320440907066649811
Many thanks and greetings!
Logged
mengfei
Regular Contributor
Country:
Reply #3 on:
August 27, 2018, 09:53:16 am »
I could open the file but there's nothing there, the vocore2-pads is only 9kb, could there be something wrong when you saved it to asc format?
Logged
violet221
Newbie
Country:
Reply #4 on:
August 27, 2018, 10:14:00 am »
Hello Mengfei
Once more thanks for Your effort, I just tried to export this schematic once more and I'm confused, export was created sucessfully but .asc file is still 9kb and it looks like it's not format what we're looking for because when i select ".asc" extension there is explanation that is "PADS layout rules" file and .txt is described as "ASCII files" so maybe .txt file is what we looking for, but maybe You can try once more to import this .txt file because i think it should be valid, maybe changing .txt extension to .asc and then importing it with altium can do it's job ? I have no any further ideas what to do about this as PADS version which i use can't export other then these file extensions
Greetings !
Logged
mengfei
Regular Contributor
Country:
Reply #5 on:
August 30, 2018, 02:40:22 am »
if my memory serves me right I think there are different versions of *.asc, try to search if you can find another version or way to save as *.asc format. this is the only format Altium can open from a converted pads file AFAIK.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
