EDA => Altium Designer => Topic started by: ali_asadzadeh on December 09, 2018, 03:08:35 pm
Title: How to select multiple pads easily
Post by: ali_asadzadeh on December 09, 2018, 03:08:35 pm
I want to select some pads like dragging a rectangle to select them and use Interactively route multiple connections, But It seems the selection box does not allow me, and I should select all the pins one by one, do we have something in aid?
Title: Re: How to select multiple pads easily
Post by: T3sl4co1l on December 09, 2018, 05:34:09 pm
If you want to avoid the popup box thingy, lock the component (right-click on it, or set its property any other way).
Unfortunately the built-in select won't do non-free pads.  You could query it, maybe even write a script to make a mouse-driven InRegion query command that's more powerful than select, but yeah, more effort to figure it out. :-//
Tim
Post by: Deridex on December 10, 2018, 06:37:06 am
Try to keep the Ctrl-Key pressed while dragging the rectangle.  ;)
Post by: ali_asadzadeh on December 10, 2018, 11:54:21 am
Thanks ;) ;) ;)
Post by: mengfei on December 18, 2018, 06:21:42 am
Edit > Select > Toggle Selection
now you can click on each pad w/o shift/crtl key
