Electronics => PCB/EDA/CAD => Altium Designer => Topic started by: ali_asadzadeh on February 09, 2026, 12:54:06 pm
Title: How to select specific pad number in altium
Post by: ali_asadzadeh on February 09, 2026, 12:54:06 pm
I have a PCB in Altium Designer 26 with around 50 connectors, all using the same footprint. Unfortunately, I only have the PCB file — there is no schematic.
I need to disconnect pin 5 of all these connectors. Currently, pin 5 on each connector is assigned to the 12V net, and I want to set those pins to No Net.
I’ve tried using the PCB Filter and Find Similar Objects, but I can’t filter by pad number / pin number — there is no PadNumber or equivalent field available to select pin 5 across all connectors.
To make it more complicated, the 12V net is also connected to many other pins, including pins on a 100-pin connector, so I can’t simply select everything on the 12V net.
SO the question is How to select all pad 5s and edit all of them at once!
Title: Re: How to select specific pad number in altium
Post by: Pseudobyte on February 09, 2026, 05:51:45 pm
(ObjectKind = 'Pad') And (Name like 'J*-5') AND (Net = '12V')
Post by: ali_asadzadeh on February 10, 2026, 12:36:52 pm
Thanks for the feedback
