Author Topic: How to narrow down search in SVNDBLIB?  (Read 553 times)
Offline mengfeiTopic starter
  • Country: ph
« on: August 04, 2023, 02:56:38 am »
is there a way to narrow down the search in SVNDBLIB? I can only search for one line & no separator can work.
say searching for a 75ohm 0402 5% Yageo type, i can only place 75ohm in the search bar, is there a way to filter a search? thanks
Offline ajb
Re: How to narrow down search in SVNDBLIB?
« Reply #1 on: August 04, 2023, 03:10:31 am »
Not as far as I know, but you can select columns for hierarchical grouping which may help: https://youtu.be/7id84tbtCPQ
I’ve set up my dblib to take advantage of this, with a set of hierarchical category columns used for grouping.  So for example I can select resistors > 0402 and then search for ‘75R’ (or more likely, just sort by value and scroll through the list). Works well enough.
  • Country: ph
« Reply #2 on: August 04, 2023, 05:43:21 am »
OK, thanks.
I'll look into that
