Author Topic: Internally conected pins, how to deal with?  (Read 5533 times)
Offline ElektroQuarkTopic starter
    • ElektroQuark
« on: February 28, 2014, 08:48:07 am »
Hello,
I want to make a schematic and footprint symbols for the typical 4 pin pushbutton.
It has two pairs of pins connected internally.
How must they be managed so if one of them is connected to a net Altium sees both connected? Same name? Setting any internal property?
Thank you.
Offline poorchava
  • Troll Cave Electronics!
Re: Internally conected pins, how to deal with?
« Reply #1 on: February 28, 2014, 08:53:27 am »
You can place multiple pins in footprint editor that will have the same designator. When you doubleclick a pin (or righclick and go to properties) there is 'designator field'. The effect is that you have multiple package pins connected to one schematic pin.
    • ElektroQuark
« Reply #2 on: February 28, 2014, 08:55:39 am »
So I need a two pin schematic symbol not a four pined one.
Offline Psi
« Reply #3 on: February 28, 2014, 09:09:54 am »
The schematic symbol will have 2 connections, eg. designator 1 and 2
The footprint will have 4 TH/SMD pads  two with the designator of 1 and two with the designator of 2
    • ElektroQuark
« Reply #4 on: February 28, 2014, 09:11:19 am »
Solved.
Thank you.
Offline poorchava
« Reply #5 on: February 28, 2014, 11:56:39 am »
Small note: I consider doing the above a bad design practice in general. For a small design and uncomplicated parts it's ok. I try as much as I can to have a schematic symbol that has exactly one symbol pin per one package pin. just a good design practice.
Offline Rufus
« Reply #6 on: February 28, 2014, 02:39:28 pm »
That depends on if you consider a schematic to be a graphical method of entering netlist and partlist to make a PCB  or if you consider a schematic to be a document showing the scheme of a circuit.
    • ElektroQuark
« Reply #7 on: February 28, 2014, 02:56:25 pm »
How is done "the proper way" then?
Offline tszaboo
« Reply #8 on: February 28, 2014, 03:19:21 pm »
Depends how you want to connect the button. You can tell alitum that they are internally connected, (in the SCHlib editor) but that can lead to a design, where two GND regions are only connected through the button. I dont recomend that option for this.
The best way to do this is to have all four pin on the schematic, and enable pin swapping for the two pairs.
