Author Topic: Altium traps: stuck by accidentally setting search path to root...  (Read 1448 times)
Offline ByonnemTopic starter
  • Bachelor Student EE
Hi Guys,
I made a mistake... I set the library search path accidentally to the root, and hence it is scanning my entire harddisk.. |O
It seems that I  cannot cancel it with ESC. or any other key for that matter and thus had to force it to terminate with task manager. Which luckely  only resulted 5 min of work lost.
The plus side is, the program is proofing to be very stable, it was not crashing, and I did not get a "does not response" warning from windows... (which you do get from many other programs such as the adobe suite and certain autodesk programs when a user makes the same error)
O well, I learned my lesson. But it still is very silly that one cannot cancel a running task...
Any other traps or good Altium advise for a "young player"?
M.D.S
The following users thanked this post: E-Design
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Altium traps: stuck by accidentally setting search path to root...
« Reply #1 on: June 08, 2020, 01:52:03 pm »
Shortcuts are attached to the toolbar, do not customize the toolbar. On time i hid all the buttons because i rarely if ever use them. Doing so disabled all my hotkeys, and I was struggling to put two and two together. Here I am trying to press delete to remove a component and nothing was happening.
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: Byonnem, E-Design
Offline sean0118
« Reply #2 on: June 15, 2020, 05:31:44 am »
Yes, when using the IPC footprint wizard don't enter a stupidly high number of pins to see what happens, not even for a joke.
It turns if you try to generate a 1000 pin part the wizard breaks. Also, each time you open the wizard it automatically loads in the previous values used, so it crashes again on open...   :scared:
Trust me, I';ve already tried it so no one else has too.  :-DD
The following users thanked this post: thm_w, Byonnem
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: June 15, 2020, 08:20:33 am »
Yeah, this threw me for a loop going from 17 to 18+...  At least there's an option (Tools/Preferences, System?, Advanced) to hide it without disabling the shortcuts.
Seven Transistor Labs, LLC
« Reply #4 on: June 15, 2020, 08:48:24 am »
hahaha. This is now really tempting, but i'll withhold myself from doing it. :-DD
Thanks for the tip!
M.D.S
