Author Topic: Shorts due to Via Stiching  (Read 2371 times)
Offline steven4601Topic starter
« on: September 06, 2017, 02:59:25 pm »
Hi ,
In a (nearly) finished 4 layer design, adding via stiching ignores most of the traces & planes.
This results in a short-circuit pile of rubbish.
The worst part is, the short circuits are not detected by the DRC or online DRC checker tool.
 :box: Altium
What did I do wrong?
Offline Just1
Re: Shorts due to Via Stiching
« Reply #1 on: September 13, 2017, 10:42:07 am »
Hello,
What version of Altium Designer?
Offline julianhigginson
« Reply #2 on: September 13, 2017, 01:37:21 pm »
owch!
that's a good reason to ring AD support, I think... send them the files if your kind of work permits it, and get them to figure it out.
Offline Araho
  • Country: no
« Reply #3 on: September 13, 2017, 01:38:32 pm »
Those vias don't look like they're all the way from the bottom of the board to the top? Have you ensured that they are actually all layers and not buried / blind vias?
« Reply #4 on: September 15, 2017, 11:14:43 am »
The Vias are from top to the bottom.   I managed to fix it , atleast for a while is to close AD, then start it again, first thing add / recreate the via stitching and hit generate gerbers  :D
Ill talk with my manager if I can send the files to Altium support for investigation. But it looks like a pretty good bug.  The DRC being completely happy with it scary as F$CK.
//Steven
« Reply #5 on: September 19, 2017, 06:57:31 am »
Altium loves a good restart every now and then... Unfortunately it takes ages to boot, so you aren't so likely to do it on a deadline..
Also, never ever release a board without a nice close look at the Gerbers after exporting them. Normally they are fine, but the one time they're not you'll really wish you had...
Offline blackfin76
« Reply #6 on: September 19, 2017, 09:34:35 am »
This may sound very obvious but are you sure your design rules are set up properly?
