Greetings all,
I have an existing Multi channel board design which has been Re-annotated at the board level and the physical designators pushed back onto the schematic. OK no problems except that the original channel A,B,C,D suffixes have been removed and replaced with your normal flattened out designators ie R111,R112,R113 instead of R47A,R47B,R47C. OK so far so good. Everything matches between schematic and PCB.
Now the nightmare starts when I add new components to the schematic. If I use Annotate Schematics then it produces duplicate designators when I compile the schematic so makes it useless now. If I use Board Level Annotation the C? and R?'s don't change at all. So how on earth are you supposed to add components to a design ? What do you use Board Level annotation for anyway ? Seems to do nothing for me.
Note that when I first did the schematic I could always correctly annotate the schematic no matter how many extra components I added. The problems start when you re-annotate at the PCB level and push back to the schematic. It has something to do with using multi channels and flattening out the designators.
This is a real show stopper for me. The only way around it is to look at the designators on the pcb and then edit the schematic so the new schematic designators don't clash with the pcb. What a PTA
cheers.
