Bluetooth_Sentinel Rev: v1
Glavkon from Altium Designer 14.09.2021 20:19:06
Placed
References
Value
[Comment]
[Description]
[DesignItemID]
[Footprint]
Qty
1C1, C2CAP 20pF 10V 0402(1005)CAP 20pF 10V 0402(1005)CAP 20pF 10V ±0.25pF 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-00871-1CAPC0402(1005)60_N2
2C3, C4, C27, C28CAP 24pF 10V 0402(1005)CAP 24pF 10V 0402(1005)CAP 24pF 10V ±0.25pF 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-00923-1CAPC0402(1005)60_N4
3C5CAP 22pF 16V 0402(1005)CAP 22pF 16V 0402(1005)CAP 22pF 16V ±0.25pF 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-00899-1CAPC0402(1005)60_N1
4C6, C11CAP 2.2uF 6.3V 0402(1005)CAP 2.2uF 6.3V 0402(1005)CAP 2.2uF 6.3V ±10% 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-02125-1CAPC0402(1005)60_N2
5C7, C8, C10, C19, C21, C22, C23, C25CAP 100nF 6.3V 0402(1005)CAP 100nF 6.3V 0402(1005)CAP 100nF 6.3V ±5% 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-02060-1CAPC0402(1005)60_N8
6C9, C12, C13CAP 470nF 6.3V 0402(1005)CAP 470nF 6.3V 0402(1005)CAP 470nF 6.3V ±10% 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-02103-1CAPC0402(1005)60_N3
7C14CAP 33pF 10V 0402(1005)CAP 33pF 10V 0402(1005)CAP 33pF 10V ±0.5pF 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-00985-1CAPC0402(1005)60_N1
8C15, C24CAP 1uF 6.3V 0402(1005)CAP 1uF 6.3V 0402(1005)CAP 1uF 6.3V ±10% 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-02113-1CAPC0402(1005)60_N2
9C16, C17CAP 100nF 16V 0402(1005)CAP 100nF 16V 0402(1005)CAP 100nF 16V ?0% 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-02069-1CAPC0402(1005)60_N2
10C18CAP 1uF 16V 0402(1005)CAP 1uF 16V 0402(1005)CAP 1uF 16V ?0% 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-02119-1CAPC0402(1005)60_N1
11C20CAP 10uF 10V 0603(1608)CAP 10uF 10V 0603(1608)CAP 10uF 10V ±20% 0603 (1608 Metric) Thickness 1mm SMDCMP-1035-02800-1CAPC0603(1608)100_N1
12C26CAP 1.5pF 10V 0402(1005)CAP 1.5pF 10V 0402(1005)CAP 1.5pF 10V ±0.1pF 0402 (1005 Metric) Thickness 0.6mm SMDCMP-1034-00102-1CAPC0402(1005)60_N1
13FL1LFB212G45SG8A143LFB212G45SG8A143LFB21(0805)_SG Series Filter for Wireless LAN/Bluetooth, 2400-2500 MHz, 2 x 1.25 x 0.95 mmCMP-0453-00001-1MUR-LFB212G45SG8A143-41
14L174479667447966SMD-Multilayer Inductor WE-MI, L = 4.70 µHCMP-0221-00043-1SMD-06031
15L2MMZ1005Y152CTMMZ1005Y152CTChip Bead for Signal Line, 1500 ohm at 100 MHz, -55 to 125 degC, 1.0 x 1.0 x 0.5 mm SMDCMP-0457-00001-1TDK-CHIP-2_V1
16LED1, LED2, LED3, LED4, LED5, LED6LNJ247W82RALNJ247W82RAHight Bright Surface Mounting Chip LED (Red), 55 mW, -30 to 85 degC, 1.0 x 0.5 x 0.2 mm SMDCMP-0456-00001-1PNSC-CHIP-2_V6
17R1, R24K7 5% 0402(1005)4K7 5% 0402(1005)4K7 0.063W 5% 0402 (1005 Metric) SMDCMP-1011-00090-1RESC0402(1005)_N2
18R3, R4, R5, R6, R7, R8200R 5% 0402(1005)200R 5% 0402(1005)200R 0.063W 5% 0402 (1005 Metric) SMDCMP-1011-00057-1RESC0402(1005)_N6
19R9, R10, R12, R13, R14, R15, R1610K 5% 0402(1005)10K 5% 0402(1005)10K 0.063W 5% 0402 (1005 Metric) SMDCMP-1011-00098-1RESC0402(1005)_N7
20R11Jumper 0402(1005)Jumper 0402(1005)Jumper 0402 (1005 Metric)CMP-1011-00001-1RESC0402(1005)_N1
21U1CSR1010A05-IQQM-RCSR1010A05-IQQM-RBluetooth Low Energy Single-mode IC, 64 KB RAM and 64 KB ROM, -30 to 85 degC, 32-pin QFNCMP-0450-00001-1CSR-CSR1010A05-IQQM-R-QFN32_M1
22U224AA512-I/SN24AA512-I/SN512K bits I2C™ Serial EEPROM, 1.7 to 5.5 V, 400 kHz, -40 to 85 degC, 8-pin SOIC (SN8), TubeCMP-0159-01018-1MCHP-SOIC-SN8_N1
23U3LIS331DLTRLIS331DLTRMEMS motion sensor 3-axis - ± 2g/± 8g smart digital output nano accelerometer, -40 to +85°C, LGA-16 (3x3x1), Tape and ReelCMP-0234-00061-2LGA16-3X3X1_L1
24U4STM32F101T6U6ASTM32F101T6U6ASTM32 ARM-based 32-bit MCU Access Line with 32 kB Flash, 6 kB Internal RAM, Internal Code A, -40 to +85°C Temperature, 36-Pin VFQFPN, TrayCMP-0237-00044-1VFQFPN36_N1
25X121C00047-16.000MHz21C00047-16.000MHzCrystal, 16 MHz, -30 to 85 degC, 3.2 x 2.5 x 0.9 mm SMDCMP-0464-00001-1ITTI-21C00047-16.000MHz-4_V1
26X2, X314340272-32.768KHz14340272-32.768KHzCrystal, 32.768 KHz, -40 to 85 degC, 3.2 x 1.5 x 0.9 mm SMDCMP-0463-00001-1ITTI-14340272-32.768KHz-2_V2
