Author Topic: Impedance calculation on a two layer board  (Read 3916 times)
Offline JJallingTopic starter
« on: February 24, 2014, 09:29:33 pm »
Is it possible to get altium to calculate trace impedance on a two layer board? Is the only way, to insert a "dummy" plane in my layer stack, and use that as a reference?
Thanks in advance.
/Jonas
Offline free_electron
    • SiliconValleyGarage
Re: Impedance calculation on a two layer board
« Reply #1 on: February 24, 2014, 10:37:35 pm »
you can't do controlled impedance unless there is a plane ....
besides it is a futile experiment for a double sided board. the dielectric is so thick you need gigantic traces to get anywhere.
Offline marshallh
    • retroactive
« Reply #2 on: February 25, 2014, 01:42:26 am »
Yup, your 50ohm traces will have to be several mm wide on twolayer.. I've seen it done, but its not practical for most things.
Verilog tips
BGA soldering intro
« Reply #3 on: February 25, 2014, 07:16:25 am »
Yes, they are quite wide. According to my rough calculations, I need trace widths of about 1.3mm for 50ohm.
I'm using double-sided .5mm RO3003 for the antenna.
I guess I'll just put in a dummy plane then, and remember to remove it later on.
Thanks guys.
Br Jonas
