Author Topic: I don't change "altium schematic and pcb default values" permanently  (Read 1701 times)
Offline eemkutayTopic starter
Hello,  I don't change altium shematic and pcb default values permanently. (.dft files)
For example I change wire color, pin length etc and I checked permenent checkbox(or uncheck) and apply/OK but If i restart Altium, all settings are gone.
I also save my settings, it doesn't work. (I started altium as admin). I didn't find the problem
I use 20.1.11. (x64). I think the problem is caused by encoding(because I see "?" characters in dft file), I can change altium encoding?
Or how can I find the problem?  please can you help me?
« Last Edit: September 20, 2020, 01:40:24 pm by eemkutay »
Re: I don't change "altium schematic and pcb default values" permanently
« Reply #1 on: September 20, 2020, 06:22:10 pm »
Anybody having similar problems?
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #2 on: September 21, 2020, 02:33:40 am »
Sounds like an issue you should be contacting Altium about
« Reply #3 on: September 21, 2020, 08:31:02 pm »
I found the problem. if your location in windows isn't any English talking country. Altium don't read/write schematic and pcb default config documents exactly.
Shortly altium wants western european(windows 1252) encoding.
« Last Edit: September 21, 2020, 08:43:53 pm by eemkutay »
The following users thanked this post: ANTALIFE
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #4 on: September 21, 2020, 11:03:23 pm »
Oh well done on figuring it out, and thanks for sharing the solution
