Author Topic: Difference Solder Mask Expansion for Top and Bottom on a Via?  (Read 2843 times)
Offline sacherjjTopic starter
« on: December 12, 2013, 06:18:17 pm »
I want my vias on the component side almost tented, but open on the bottom.  This gives you the ability to capacitive test points for BGA to detect non-solder, good solder, and bridge for each via broke out ball.
I have negative solder mask expansion, top small pad, bottom large pad.  I want a fully exposed annular ring on the bottom, but can't do that on the top without possible solder bridging on the BGA.
I can't find a way to specify solder mask extension on top and bottom, just one value.  Is the possible in Altium at all?
Re: Difference Solder Mask Expansion for Top and Bottom on a Via?
« Reply #1 on: December 12, 2013, 07:42:10 pm »
I might be doing something very wrong.  I'm getting polygons that are GND net, joining with every via under the sun.   |O
