I am using Altium Designer 21.6.4.
I have draw schematics, switched to pcb. Previously when I click on the schematic parts it also indicate/ highlights component in pcb. After I made some net classes I cant move parts in pcb.
What I did from Altium Designer help link as follows,
To have the connection lines move with the component when using Edit ► Move ► Component, as they do when just clicking and dragging the component in the PCB editor, "Comp Drag" must be set to "None". See Preferences ► PCB Editor ► General ► Other (section) ► Comp Drag set to "None". Either way, they will show on the component when things are done.
" alt="" class="bbc_img" />
Nothing happed with this setting.
Help me please,
Hasan
