Author Topic: Altium Designer Draftsman export/print to PDF  (Read 2815 times)
Offline halexaTopic starter
« on: October 24, 2018, 01:18:39 pm »
Don't know if this is a bug in Altium or if I'm doing something wrong.
I have a draftsman document with squares that have an ANSI-37 pattern fill with 50% opacity. When i export or print  the Draftsman document to PDF the fill is missing.
And i tried to change the opacity to 100% and it doesn't matter.
Any clue, anyone?
Offline voltsandjolts
Re: Altium Designer Draftsman export/print to PDF
« Reply #1 on: October 24, 2018, 09:07:39 pm »
Never used draftsman but maybe its the Altium PDF exporter - maybe try printing or print to XPS/PDF.
If all else fails, your screenshots look OK to me ;D
« Reply #2 on: October 26, 2018, 08:03:37 am »
I caved in and went with a solid fill with 50% opacity. Did not found a work around for ANSI fill
