Author Topic: L M and N  (Read 27353 times)
Offline GregoryTopic starter
    • All Electronics Channel
L M and N
« on: March 11, 2013, 06:19:14 am »
Guys. When I put a smd component I can choose M, L or N footprints? What is the diference between than?
Offline electroguy
Re: L M and N
« Reply #1 on: March 11, 2013, 09:35:27 am »
I can't remember what each one stands for, but it refers to the size of the footprint/pads.
As an example, it's something like this for chip resistors, 0603, 0805 etc... (you can pick a footprint from each one and use CTRL+M to prove it's size).
L - about 10% smaller than N - use this if you are really tight for space.
N - NORMAL size, use this most of the time, if it suits you.
M - about 10% larger than N - use this if you want a larger than normal footprint.
There are 10 types of people that understand binary, those that do and those that don't!
The following users thanked this post: electronx
Offline Psi
Re: L M and N
« Reply #2 on: March 11, 2013, 10:36:04 am »
Yeah, as said above, it's for different board densities (how close you want to pack the components)
Use M If you're soldering by hand, it will make things easier.
Offline AlfBaz
Re: L M and N
« Reply #3 on: March 11, 2013, 02:09:13 pm »
Least, Most and Nominal density I think are IPC nomenculture
For a given component they stipulate the size of the pads and talk in terms of heal, toe etc.
Essentially, least will be a very big pad and Most will be a very small pad thats why electroguy and psi are saying that Nominal is usually ok for hand soldering
Offline enz
Re: L M and N
« Reply #4 on: March 11, 2013, 04:28:21 pm »
Sorry, but it is the other way around.
Least: means the least space occupied, --> small pad --> high density --> difficult for hand soldering
Nominal: means normal sized pad, between Least and Most
Most: means the most space occupied, --> big pad --> low density --> easy to hand solder
Martin
Re: L M and N
« Reply #5 on: March 11, 2013, 05:02:39 pm »
Thanks guys. So the component size and package are the same? but what changes is nly the pads? right? It's my first SMD pcb, I will use M so. I wilk make the board on OSH park, you think I wii get to use 0603 resistor? or is better I start with 0805? thanks
Offline mrflibble
Re: L M and N
« Reply #6 on: March 13, 2013, 04:29:59 pm »
If you have the pcb room I'd say go for 0805, that makes it a bit easier for hand assembly. Currently doing a layout as well for a 5x5 cm board. And at first I wasn't sure if everything was going to fit so I started out with 0603 parts. But turns out that there's room after all, so I changed all the 0603's to 0805's purely to make things a bit easier for myself.
Using N (nominal) pads here for the 0805's.
