Author Topic: Layer appears negative when gerbers are generated  (Read 1641 times)
Offline MarkTopic starter
« on: September 27, 2023, 01:56:27 pm »
I converted a design from PADS to Altium and generated the gerbers from the (modified) Altium design.
I imported the PADS gerbers and Altium gerbers into CAMtastic files for comparison.
It looks like one of the internal layers is now a negative:
(old PADS vs new Altium)
I've never seen this before, is it a problem with settings or will the PCB fabricator know it is negative?  (Yes, I did ask them, but no response to the question, just a quote).
thanks.
Edited to add: This is the only layer that shows up as a "plane".  Normally I would just use a poly pour but this is the way it imported.
« Last Edit: September 27, 2023, 02:22:10 pm by Mark »
Offline ajb
Re: Layer appears negative when gerbers are generated
« Reply #1 on: September 27, 2023, 02:41:27 pm »
That's just how Altium exports plane layers.  Your only options AFAIK, are to leave the gerber negative and let your fabricator know, or to replace the plane layer with a signal layer and place a polygon.  Since plane layers are pretty straightforward, it should be fairly low risk to do the latter, as long as there aren't any complicated clearance/connection rules or voided areas.
The following users thanked this post: Mark
