Author Topic: Different PCBs in a Single Project  (Read 3713 times)
Offline mathwizTopic starter
« on: September 25, 2014, 10:28:24 am »
I have 3 separate boards each with a unique PCB design:
One 4 layer board, two 2 layer boards (each measuring 2.8cm x 6.2cm)
--> Is there a way Altium lets you do the design in a single project AND single PCB file, and using V-Grooves / Mouse Bites in order to panelize the boards?
Doing so will reduce the manufacturing cost, since combining the boards will lead to a bigger but a single PCB order as opposed to ordering 3 separate boards, which will cost more.
Any help and comments appreciated. Cheers.
Offline Precipice
Re: Different PCBs in a Single Project
« Reply #1 on: September 25, 2014, 10:32:53 am »
Make a new blank PCB, then place copies of your existing PCBs using
Place -> embedded board array / panelise
then draw your v-grooves / mousebites as you like.
Note that not all PCB shops are keen on this.
« Reply #2 on: September 25, 2014, 10:58:52 am »
Thank you for your response. The problem is that I have 3 different Schematic Sheets, and each PCB design requires only the components from 1 Schematic Sheet - and as far as I'm concerned Altium does not give you the option to choose which Schematic Sheet you want to include, it just includes everything by default.
The panelisation comes after I design the 3 different PCBs in a single project - but up till now I was unable to find a solution other than designing the boards in 3 separate projects. What would you suggest? Again, thank you!
Offline Precipice
« Reply #3 on: September 25, 2014, 11:07:49 am »
Yes, three different projects, combined into a panel (which might be a 4th project, if you like).
They're different projects - go with it!
« Reply #4 on: September 25, 2014, 11:26:11 am »
Thanks ;) Just wondering though, is there a way Altium let's you do this in a single project as opposed to creating separate project? I think a solution would be to define rooms, and then delete the room which is not required for the PCB.
Offline Precipice
« Reply #5 on: September 25, 2014, 12:00:52 pm »
Sounds like a pain in the arse, but sure, you could do it that way.
(there are many, many ways to achieve most things in most CAD packages. Pick the one that revolts you the least, and go with it :)
Also, if you're thinking of machine-populating these boards, then one project, and rooms, will get you properly functioning unique part IDs.
Offline mengfei
  • Country: ph
« Reply #6 on: October 15, 2014, 09:42:55 am »
one EE did it that way, having 3 SCH/ 3PCBs in just one file project
it was a pain to deal with, not to mention with same designators  :palm:
http://forum.live.altium.com/#posts/206268/572773?msgID=11177801
Offline ludzinc
    • My Misadventures In Engineering
« Reply #7 on: October 15, 2014, 10:00:20 am »
 :wtf:
A 4 layer design AND two 2 layer designs on the one panel?
 :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared:
