Author Topic: should I learn Altium or Cadence software?  (Read 3472 times)
Offline kamrat7Topic starter
« on: July 18, 2015, 02:42:09 am »
I'm deciding which software to learn - Altium or Cadence Allegro / OrCad?
Which software is more often used in the industry in big companies?
If I were to learn one, which would be a better investment?
Thanks everyone!
Offline T3sl4co1l
    • Seven Transistor Labs
Re: should I learn Altium or Cadence software?
« Reply #1 on: July 18, 2015, 05:18:37 am »
Altium has been my experience.  If you like, search job listings for SCH/PCB design / layout work, and see which ones show up more often.
Seven Transistor Labs, LLC
Offline Neilm
« Reply #2 on: July 18, 2015, 06:33:41 pm »
Every where I have worked has preferred OrCad. I would have thought that as long as you had some experience with a schematic capture package and PCB layout I would have thought a reasonable employer would get you training. Of more importance is knowing good layout methods and techniques.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
