Author Topic: Change component pad colors by net?  (Read 5341 times)
Offline ThebrakshowTopic starter
« on: May 16, 2013, 03:07:46 am »
Hello All,
Is it possible to change component pad colors by net in Altium? I usually use Allegro and here is an example of this in Allegro ( See strapping resistors for U1). Thanks for any help in advance!!
Offline Fox
  • Electronics Engineer
Re: Change component pad colors by net?
« Reply #1 on: May 16, 2013, 08:20:47 pm »
it is possible with Altium too change the Net colors, afaik it is not possible for individual pads.
http://wiki.altium.com/display/ADOH/Customization+of+Net+Colors
A closed Switch should have zero Ohms or less!
